Posted by Janicholson on January 29, 2011 at 19:42:30 from (67.72.98.57):
In Reply to: M engine posted by poco on January 29, 2011 at 18:36:08:
247.7 was the gasoline engine displacement from the factory. The engine has likely been rebuilt one or more times, so there could have been changes, the most common is 264 Cubes if the Thin sleeves were used to match a Super M. But larger displacements can be provided with running the piston in the cast bore, and boring the cast bore larger and even bigger pistons. Stroking is also possible, but not likely unless someone was carried away. Displacement could be taken with a fluid in the cylinder and measured for volume, but it depends on how earnest you are in determining the displacement. Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
