You need to do several things. 1. The diff bearings (I am assuming they are tapered roller bearings) need to be set to the proper rolling drag. 2. The ring gear needs to be set to the proper location left to right. In some cases, numbers are stamped in the gears and diff case which will allow you make a calculation for the proper ring and pinion gear location. 3. The pinion bearings need to be set to the proper rolling drag. Again assuming they are tapered roller bearings. 4. The pinion needs to be shimmed to the proper fore aft position to give the proper pattern and lash. You will need a manual to get the bearing pre-load numbers, pattern location (it should be near the heel), and lash. Some mfrs use threaded quills to simplify the adjustment process. If yours are shimmed, it will take some time to get it right. Might want to consider paying the money to have set by someone with experience and tools.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
