With the tractor in low range, step on the foot-n-inch pedal (where the clutch would be if it was a gear drive), move the hydro lever into the blue area of quadrant, half throttle or so, hold the brakes, and let out the f-n-I pedal. A good hydro will overpower the brakes. In high range, same procedure, it should stall the engine. If the hydro starts whining instead of moving, the hydro has a problem.
you can get the hyd oil warmed up some, by putting the hi-lo lever in neutral and pushing the hydro lever up about halfway, before you test the hydro. i screwed up on a 186 hydro one time by trying it when the oil was stone cold. seemed ok but it wasn't.
for $2800, i'd be tempted to take a chance, unless there is a major problem like worn out tires. i had the hydro on my 826 rebuilt at hoober's for $2300, plus i split the tractor and put it back together. i didn't think that was too bad for a new hydro. you may not even need to do that much.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
