Posted by John T on February 05, 2011 at 06:30:35 from (66.87.11.109):
In Reply to: 504 generator posted by dan mcdonald on February 05, 2011 at 04:31:13:
A person may have some luck in cleaning/buffing/polishing the contacts on the cutout relay (one of the coil relays inside the Voltage Regulator) but do it gently as once all the shiny silvery coating is gone they can stick again. Its supposed to be open when shes setting not running (otherwise the genny draws current n spins like the DC motor it is) and be closed only when the genny is running and at higher then battery voltage. Id insure the VR has a good clean solid connection to case/frame ground often on the Generator body or elsewhere.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
