Re: Part name and availability
Posted by ScottyHOMEy on February 12, 2011 at 09:36:32 from (70.105.243.38):
In Reply to: Part name and availability posted by bkpigs on February 12, 2011 at 07:38:36:
If I'm reading your question correctly, the IH manual refers to that as "where the valve lever contacts the valve stem contact," so it doesn't really have a name. It is not an insert, but that surface is hardened. It will wear, but a machine shop can resurface it, as long as there is enough hardened material there to work with.
As far as getting a blade in there, it needs to be a narrow one, as close to the width of the valve stem as you can manage. The surface of the arm is intentionally cupped -- the valve stem moves in a straight line while the arm moves on an arc, and it's that cup that keeps the pressure on the valve stem straight up and down.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
