Re: IH Tractor Model 464 gas
Posted by Owen Aaland on February 12, 2011 at 23:10:51 from (65.174.247.20):
In Reply to: IH Tractor Model 464 gas posted by VACLee on February 12, 2011 at 12:36:53:
I think you will find that the resistor is built into the wiring harness on that model. The resistor is actually the wire that comes from a connector near the ignition switch and goes to the starter solenoid. the wire itself under the insulation will be a silver/gray color rather than plain copper.
The way to tell for sure is to look at where the wires connect to the ignition coil and at the I terminal on the solenoid. If the coil has two wires attached on the battery side and the solenoid has only one there will an external resistor somewhere near the coil. If the coil has only one wire attached coming from the ignition switch and the solenoid has two on the I terminal you have the resistance built into the wiring harness.
If you find the wire is broken you can try repairing it or just replace that section of wire with copper and adding an external resistor.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
