The Answer.........
Posted by Dellbertt on February 13, 2011 at 07:12:37 from (209.172.21.100):
In Reply to: 300U Fast Hitch Down pressure posted by Dellbertt on February 06, 2011 at 05:28:40:
504 had the correct answer. I thought I had checked the free float pin but I apparently looked at the incorrect slot. Either the pin had come out or was never there in the first place.
Here’s how I found the answer.
I backed up to my old Caprice and stuck the fast hitch under the rear bumper. The fast hitch raised that ol’Chev 2 ft off the ground like it wasn’t even there. I shut down the tractor and let it set for 15 minutes and it didn’t sag an inch, so I knew the pump and screen are good and no leak in cylinder or valve. But I still could not raise the rear of the tractor with the fast hitch down pressure.
So I thought I would switch around the hoses on the cylinder to see if it would make a difference. Luckily, the debris guard and the seat had to come off to get to the cylinder hose connections and it was too cold to mess with all that.
I put a block under the fast hitch and ran it up and down watching it. I noticed there was a hesitation in the movement and as the hitch touched the block the hitch stopped but the cylinder kept moving. Bingo! The lightening bolt of enlightenment!
I remembered “504” stating that the pin might be missing allowing the hitch to free float. I had checked that pin but on watching the hitch move I saw that I had checked the wrong hole and the float pin was indeed MISSING.
After I placed a hitch pin in the correct hole the fast hitch raised the rear of the tractor with no effort at all. And a good thing too, I found I had a broken cross link on my tire chains to repair.
Several times on this forum I have given the advice to start from the beginning, checking all the basics first.
I guess I needed a reminder to take my own advice.
Thanks to all for sharing good advice and especially 504 to “check the basics first”
Dell
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
