Posted by Janicholson on February 14, 2011 at 06:24:41 from (199.17.6.194):
In Reply to: M Block repair posted by FarmerBrawn on February 14, 2011 at 06:03:29:
A cut is easy to repair. If it is easily accessed and not too deep, a braze job on it would be pretty easy and certain fix. If it is a crack, then it will be more difficult.
The sleeve ring at the top of the cylinder bore is usually wide enough to prevent water leaks across the gasket into the cylinder. If the sleeve is cracked, just replace it. Fixing a sleeve is like taking a 20 dolar watch in for circuit repair. A cut in the casting of the block into a water passage is not good, but if not drastic, will not prevent the reliable operation of the engine. If the crack is drastic when the sleeve is pulled, the cylinder can still be saved with a repair (thick) sleeve installed into a bored out block, then re-machined for the liner sleeve ring. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
