Posted by troy schubert on February 14, 2011 at 19:16:56 from (76.24.64.57):
My hydraulic fluid keeps foaming up. I just re-built the dual stage pump (new o-rings and front shaft seal), filled with correct amount of fluid, and can't seem to get the air purged from the system. I also cleaned the suction filter.
I have a front end loader. 4 to 5 times I've started the tractor, extended the FEL to max, then allowed to go back. Also operated 3pth. then shut off engine to allow air to settle out. When just using power steering, system seems to be ok. As soon as I start using the FEL, the fluid fizzes up like sodie pop.
I'm really scratching my head where all of this air is coming from. I can't see that I have leaks anywhere. Any ideas?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
