This is a common problem for tractors where it has been many years since they were split between the center section and the rear frame. there is an O-ring seal between those two housings to connect the suction side of the MCV pump. As the o-rings ages it becomes less effective at sealing between the two housings. Since the seal is above the oil level air enters on the suction side of the pump. When you start the tractor this air is drawn into the MCV pump which is not very good at pumping air.
The short term solution is to add about five to seven gallons of oil above the full mark on the stick. That puts the oil level above the seal so air will no longer enter the MCV pump. The only downside is that when you change hydraulic filters you will also drain out some of this extra oil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
