I may be wrong on this, but I believe the correct marks should be in position next to the governor gear to do the alignment when the engine is turned to #1 TDC. Set your engine at #1 TDC . Whether the marks are one each on adjacent teeth or close together between two teeth, just use them.
In any case, after installing the governor, the distributor drive slot should be about 35 degrees off of horizontal. (oriented 2 - 8 o'clock when viewed from the distributor end). If you have that orientation at TDC, you are in business.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
