Re: How often do you use your Road Gear?
Posted by The Dukester on February 19, 2011 at 18:50:05 from (209.86.226.56):
In Reply to: How often do you use your Road Gear? posted by Faster346 on February 16, 2011 at 19:18:03:
You can use road gear all you want using good judgement as to how rough the road is your running on and the weight of the load you're trying to pull....don't make a habit of overloading the engine or "grinding the gears" shifting into road gear from 4th on the go. Farmall H's and M's will start slipping out of 5th if you grind the gears shifting them into 5th on the go too much because it is a dog clutch you are engaging and if the teeth get rounded off on the companion clutch members the detent on the shift rail cannot hold the dog clutching gears in engagement. Also if you bounce an H or M family tractor around too much on rough ground (especially in road gear) it will eventually break the capscrews (bolts) holding the clutch housing to the transmission housing. These capscrews are inside the housing and you might not notice any of them broken until it's too late.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
