Not familiar with the location of the particular seal, but will assume it's the typical stamped seal casing with the rubber lips in the middle.
When they're stuck hard, I usually suggest heat and penetrants, almost like busting a stuck bolt free. Heat both, the seal and the surrounding metal. As it cools, shoot your favorite (PBBlaster . . . ) onto the seam while it's still hot but cool enough that it doesn't sizzle away. As it cools it will draw the stuff in. Might take several cycles of that -- the heating and cooling will mechanically break up any rust holding it, and the penetrant will do what it does.
As for the mechanical part of pulling . . . I dont know how much you've buggered up what you have. There's the standard tool made for pulling, kind of like a double-ended narrow hammer claw. If that isn't gonna work in your situation, the most common alternative is to drive a couple of screws into the face of the shell of the seal and use a prybar to pull from under the screwhead -- it works well but works better if you've at least applied a penetrant, and even better if you put the heat to it, as well.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
