Re: Mag Question
Posted by Phil Auten (TX) on July 17, 2000 at 05:18:25 from (206.175.72.226):
In Reply to: Mag Question posted by Brian Schmidt on July 15, 2000 at 20:20:41:
Brian, It is also possible that the mag has been converted to a distributor ignition. I have one tractor that has been converted and it works, but of course is not original. Either type of ignition will work, the choice is up to you which one you want to keep. Here's a brief rundown on how both types of ignitions work: The mag has a spring loaded impulse coupling built in to assist with starting. It's function is to make the spark hotter at cranking speeds and it is no longer employed once the engine is running. It will make an audible click as the engine is rotated by hand. The impulse trips at the exact time needed to cause the magnets in the bottom of the mag to rotate quickly past the small coil of wire that is the primary side of the ignition circuit. The current induced into the primary is then interrupted by the points opening. This causes the magnetic field arount the primary coil to collapse immediately. The collapsing magnetic field induces a current in the secondary winding of the cignition coil which creates the spark voltage for the plug. The battery ignition works in a similar way, but the points carry current from the battery through the primary side of the ignition coil, building up a magnetic field until the points open, causing the rapid collapse of the magnetic field which induces the spark voltage in the secondary winding of the ignition coil. The battery ignition is quite a bit simpler which explains the conversion of many mags to battery ignition, or their replacement with a battery ignition distributor. Hope this is helpful, Phil
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
