Posted by Owen Aaland on February 24, 2011 at 12:53:49 from (65.174.247.39):
In Reply to: 1066 hydraulics posted by Michael Sheik on February 24, 2011 at 05:46:01:
The MCV hydraulics are separate from the hitch. The failure to lift properly is most likely caused by a weak pump. As pressures go up the pump flow decreases.
The problem with the baler not maintaining pressure is either in the cylinder(s) on the baler or a auxiliary valve leaking past the spool lands. There is no repair for that valved problem other than replacement of the entire valve. Many balers have a double acting check valve mounted on the tensioner system to maintain the pressure rather than rely on the tractor control valve. If yours has a check valve that also may have failed.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
