Rtkman.Heck of a lot of tension on the brush holder spring assembly. I would pull the starter apart and check the armature with a volt ohm meter to see if there is a section (or sections) that are Dead. Ground the volt ohm meter (ground clip it to the end of the steel shaft side.Rum the other VOM Hot around the armature ,watching to make sure there is NO CONTINUITY SHOWING ON THE GAUGE. if there is, good by armature assembly. Son is sending a service bulletin to help.Regards,LOU
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
