Posted by Janicholson on March 02, 2011 at 13:41:03 from (199.17.6.194):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Beyond the ideas below are two possibilities. The pilot bearing on the snout of the clutch shaft (center of flywheel) can be dry or gummy and cause drag. Most can be lubricated, check the manual. A slightly warped disk can drag on the PP or Flywheel and also cause spinning of the gears. Push in the clutch and count to 10 then shift. If it still grinds, check the level of fluid in the trans. If it is low, or someone put hytran in it rather than the 80-140 oil it should have, will also allow excess gear run on. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
