Posted by gene bender on March 02, 2011 at 14:23:17 from (67.55.227.7):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Probably its the pilot bearing in the crankshaft dry and dirty. There is no way to get any lube to it without splitting. Make sure the trannys lube is up to the level. The level plug is behind the brake rod on the left side. Use 90wt. Mite also want to check the free pedal on the clutch to make sure when pedal is pushed the disc is free. You can lube that bearing from the left side bell housing. You can use a lite to see the zerk.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
