Made brackets to mount pump to injection pump timing cover, complete with a tensioner screw. I used a 3.5" pulley and it works great. Also the B belt runs lower in the fan pulley groove where it isn't all worn out.
Diesel engine turns normal, only the distributor has a problem because of extra gear in the chain.
So far the only MD setup I have seen completely under the hood is one similar to yours, but with a separate tank. The guy drove it off the crank with another belt and had to move the fan forward to clear the belt, also trimming the shroud a bit to let the belt pass. He mounted the steering pump directly above the injection pump gear. That had to have been kinda ugly to do as I just examined that tradeoff and it isn't easy because of the way IH water pump is built. I have a picture of it but posting here is so annoying I don't use it.
PS: If you ever have cold starting problems, like when it chuffs and won't catch, drop the air filter cup.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
