Posted by mkirsch on March 03, 2011 at 05:23:53 from (64.80.110.75):
In Reply to: Grinding the Gears posted by Enar on March 02, 2011 at 13:03:57:
Make sure the clutch is adjusted properly.
I had a Cub that was like this. If you let out the clutch while it was in neutral, you were screwed. The only way to get it back into gear was to let it grind until everything stopped spinning. Going from gear to gear was fine, but that was because the wheels stopped the transmission from spinning.
In my case, I went in through the clutch inspection hole in the bottom, and made a slight adjustment to the three fingers on the pressure plate, so that they had just a hair more travel.
All I did was loosen the lock nuts and turn the adjustment screws about 1/8 of a turn. Can't remember which direction, though.
The purpose was to get more lift on the pressure plate so that it would release the clutch disk. It worked. No more grinding.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
