Re: Propane help for Larry McDonald
Posted by Wardner on March 06, 2011 at 09:10:53 from (209.86.226.34):
In Reply to: Propane help for Larry McDonald posted by KenB_Texas on March 05, 2011 at 22:51:59:
Larry wants to know how to start his "new-to-him" LP tractor.
This begs the question: Have you seen it running? If so, turn on the vapor valve, move the throttle half way, turn the ignition key, and probably play with the choke. Not much different than a gasoline engine. If you are going to work it hard, turn on the liquid valve.
If the ignition is OK and it won't start, you are either out of fuel or the regulator is faulty. There is a small likelihood that the shutdown diaphragm in the carb is faulty but that is your lowest priority troubleshooting step. The diaphragm shuts down the fuel flow when there is no intake manifold vacuum.
Check to see if anyone has been wrenching on the regulator. If so, someone else (or the IH manual) will need to assist you.
I have a W-400LP but have only started it half a dozen times and refueled it once. I had to replace the regulator after not running the tractor for many years. The internals were heavily corroded.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
