Yes check the torques. I have found loose ones on occasion. Mine seeps oil at that spot when under heavy load and the oil is too thick for the cold weather that set in before I was ready for it. All bolts are at full torque too. That area of the head doesn't get a lot of clamping pressure apparently.
I would throw in some stop leak or some pepper and have a go at it. It will likely leak less when warmed up well. With two acres you won't be stressed from watching the temp for days on end and be likely to forget, and if you have a two bottom then life gets easier too. On the other hand, running a disk will put some heat in it. Those things can be a load.
Be very careful of the temperature. Do NOT let it get above 200. EVER. Once they are above the thermostat bad things happen to a gas start.
Congrats on having a runner, even if a slightly hobbled one. 8)
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
