Re: Re: Re: Super WD
Posted by David on July 19, 2000 at 12:55:39 from (209.252.117.117):
In Reply to: Re: Re: Super WD posted by E F Bazaar on July 19, 2000 at 10:53:24:
Mr. Bazzar, First, the surest and best way to tell if head is cracked is to pull the head off. Not very complicated or difficult to do. Best advice is to take some close up pics of the side of head where your starting levers hook up. No problems later when assembling. Head should be "fluxed" by any good machine shop. Older tractor parts yards here in North Dakota have these heads or any reliable older tractor parts dealer on the net has them. That is, if and only if the head is cracked. Doubtful on a WD6 but I suppose could happen. Next: to get this engine unstuck try this. Remove front grill and hood. Remove top hose from radiator/block. Use a longer hose, turn it "up" to hold water. Pour boiling, and I mean boiling water directly into block. Use a proper fitting wrench with a cheater handle 3 ft long or more to pry directly down on crank about 3 or 4 minutes after you have filled block with hot water. After the engine turns over then it is a matter of starting it on gas, then when its properly warmed you switch the two levers up to diesel. After two or three days of running it you can tell if the head is cracked if: Puffs of white smoke, poor power, hard starting, and lastly the sure sign, if your radiator goes down that water passing through the head is going somewhere, ie cracked head. Hope you have good luck, they are a good little tractor and don't worry about putting a few dollars into them. With a decent valve job they run and run for years with little upkeep. Good Luck.
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
