Re: 12V conversion question
Posted by Bob on March 09, 2011 at 19:58:32 from (173.226.56.4):
In Reply to: 12V conversion question posted by Brad Gyde on March 09, 2011 at 19:35:36:
If going 12 Volt, WHY not go to (-) ground, 'cause sooner or later someone's gonna see that 12 Volt battery and boost it or charge it (-) ground, like every other 12 Volt battery they've ever seen.
If a magneto, NOTHING needs to be changed in the switchbox, 'cept the wires on the ammeter IF you do go to (-) ground.
If a distributor ignition system, you'll have to add a dropping resistor ahead of the coil or go to a TRUE 12 Volt coil, NAPA IC14SB, for example.
Battery ignition coil... (-) side goes to distributor, if (-) ground, (+) side of coil to distributor, if (+) ground.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
