The primary advantage of converting to 12 volts is the high alternator output with an internal regulator to eliminate mechanical regulator contacts. The short coming of the older tractors 6 or 12 volt is the generator/regulator system. Generators provide relatively low charge current. When these tractors were used in the field all day long, the generator had enough time to recharge the battery. Now days when these tractors are operated with frequent starts and short run times the battery doesn't get fully charged. When batteries are not fully charge they fail. Think of it as trying to charge a battery with a 6 Amp charger (generator) or a 50 Amp charger (alternator). The alternator will provide quick battery recovery with the shorter run times. K-Mo
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
