Re: 12V conversion question
Posted by John T on March 10, 2011 at 06:53:20 from (66.87.7.160):
In Reply to: 12V conversion question posted by Brad Gyde on March 09, 2011 at 19:35:36:
If youre converting to 12 volts Id use Negative Ground sam as Bob M,,,,,,
I would use a 3 wire (BAT ARM FLD) full fledged 12 volt Voltage Regulator versus messing with a Cutout Relay and any LHBD ligth switch charge regulation. Make sure the VR is suitable for NEG ground,,,,,,
BAT on VR to load (NOT battery/starter) side of ammeter......ARM/GEN on VR to ARM post on Genny,,,,,FLD on VR to gennys FLD post,,,,,loads like lights/ignition switch get hot battery voltage supply from LOAD side of ammeter, same terminal that wires to BAT on VR. Other Supply side of ammeter gets hot battery voltage often where big battery cable wirres to starter switch.
If it was Pos ground before, ammeter leads need reversed or it will read bass ackwards.
Polarize the genny BEFORE start up
LOOK AT BOB M'S WIRING DIAGRAMS
If this isnt the answer youre looking for I dont know what to tell you
John T
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
