Posted by Dellbertt on March 13, 2011 at 07:07:49 from (209.172.21.73):
For years I have been complaining about my 300U manual steering being hard to turn while others say theirs is not that bad. After really going through the system I found it was my fault, not the tractor.
1. No. 9 in the IT manual are the two side lash adjusting screws - one on either side of the steering box. There is a lock nut on each slotted screw.
There should be a small amount of side movement of the gears to prevent binding -about 1/8 inch.
Years ago when I tightened the lock nut I must have let the screw turn also which caused binding on the gears. After readjusting the screws and lock nuts my 300U now steers easily.
2. Even though I was using the correct settings on the pitman arms, I had been using the wrong center position on my steering wheel. I was about 1/3 turn off. On my tractor center is with the correct steering wheel spoke up and centered and I had been using down and centered. I don’t know if that is factory setting or not.
Even though I still have a little more play in the right side than the left, my 300U now steers easily and tracks true.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
