Posted by Janicholson on March 20, 2011 at 14:46:38 from (67.72.98.45):
In Reply to: H Argh! posted by pete_5959 on March 20, 2011 at 14:34:40:
Pulling the oil pan will tell you the story. If a rod broke and destroyed internal surfaces, oil pump and or the block itself, it will require substantial effort to make it right. The most common problems that make internal noise are broken rods, spun bearings and broken crankshafts. All are visible with the pan off. If the block and cam are OK, and the crank was untouched, A engine Kit will be all that is needed. If there is damage to the journals and block it might just be best to get a different engine and rebuild that. Super H or 300-350 would be nice! If the crank is measured and found to be good, and the block is OK it might be an in frame proposition. Otherwise the engine will need to be removed. Jim
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
