Re: international tractor c169 gas eng
Posted by Janicholson on March 22, 2011 at 15:01:55 from (67.72.98.45):
In Reply to: international tractor c169 gas eng posted by j r pilgrim on March 22, 2011 at 06:10:47:
With respect and welcome to this site, None of us work without a manual to use as a reference. If we act like we do, it is just not the way it operates. The following was found in the Farmall archives, on this site, with 20 seconds of looking.
Quote from H service manual By CNKS:
"Drive gear keyed to camshaft; one tooth of gear marked to mate between similar marked teeth on magneto gear and cam gear has two teeth marked to straddle similar marked tooth on crankshaft gear at the same time when engine is on No.1 TDC." The IT manual is a little clearer: "---mesh single marked tooth on crankshaft gear between the two marked teeth on camsaft gear; then mesh single marked tooth on camshaft gear between the two marked teeth on magneto gear; the governor gear and idler gear need not be timed to the engine."
The Distributor drive gear is the same.
This is really a discussion forum, and we Kinda like to be chatted with, as it pertains to what you are doing and what you need. Thanks and you are very encouraged to not be discouraged. Jim
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
