Posted by pete 23 on March 24, 2011 at 20:09:45 from (173.87.15.2):
In Reply to: SLOW CRANKING SUPER C posted by John826diesel on March 24, 2011 at 16:11:24:
Yes, that ground connection inside the battery box is a real problem area and then it has to carry current from there down through the steering support etc so lots of places for voltage drop. If a trial longer ground cable doesn't help you out though , you may want to go back into that starter. The C and Super C use light starter with only two field coils and no center bearing. That means everything in there has to be in really good shape. Just a little too much looseness in the end bushings and armature will rub. I have put center bearings in many of those to support that armature. Most of the end plates do not have a replaceable bushing unless the original end plate was replaced.Wear in the bushing is the single most cause of a doggy starter, not brush's like commonly though. You can get by with more end bearing wear if the center is supported. Also, the stud for the switch is a wear item, may need to replace it also or at least polish it nice and square.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
