Zachary Hoyt said: (quoted from post at 05:43:43 03/26/11) As I understand it the 460 is a continuation of the H/SH/300/350 line and the 400/450 were succeeded by the 560. The number jump is confusing, but I guess there are only so many numbers available to use to name tractors, so what could they do?
Zach
I should have stated that better when I gave letter/number examples. I would guess (I will probably go do research) that a 460 diesel had just as much motor as an M plus a little weight.
Max Hp is 46 and at rated speed it was 44.40. That would put it at more than an M (unless it had some mods). They ran it at 9139 lbs!!! Bare it was 6055 so it is only a hair bigger than an M.
They say the M is 36.07 at rated speed and 36.66 hp max tested. They don't give a weight, but they say they added 750 lbs of cast weight. That would put it at around 6500, probably less.
This post was edited by sflem849 at 06:58:21 03/26/11 2 times.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
