80 ft-lbs is the recommended. You've had it warm, so go ahead and draw it down. Pattern is to start somewhere in the middle and work your way clockwise around the studs so that the end effect is that you're alternating ends, working out from the middle.
If it's terribly slack to start with (like under 65 ft-lbs) it wouldn't hurt to run it to warm a couple of times, and check them again after it's cooled back down. Abit of a pain in the neck becasue it means removing thte rocker and re-running the valves, but if lack of pressure on the head is the reason for the seep aroud the gasket, it will be small effort and expense for an easy fix.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
