Posted by RTR on March 28, 2011 at 08:47:28 from (216.226.179.180):
What I"ve got: Farmall Cub Tractor Serial #24,610 6 Volt Positive Ground System 6 Volt Generator Distributor Ignition New 6 Volt Battery & New Cables Voltage Regulator System (pretty sure, it has ODB light switch and not the LHDB switch)
1st Issue: When the battery cables are hooked to the posts; there is a spark. Cause: ? Possible Bad Ground ? Solution: ?
2nd Issue: Once battery cables are hooked up, the ammeter shows a discharge of about 10 amps. Tractor is not running and no switches are on. Cause: ? Solution: ?
3rd Issue: I try to start the tractor, and when started switch is engaged, it just makes a loud "pop" at the battery connection and never engages starter. Cause: ? Solution: ?
4th Issue: When I try to "reconnect" the battery connection I notice that the battery cables are fairly Warm. Cause: ? Solution: ?AL Farmall Boy Cub Star
Posts: 99 Joined: Tue Aug 10, 2010 6:38 pm Zip Code: 35111 Private message
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
