Posted by Owen Aaland on March 28, 2011 at 13:56:28 from (65.161.86.66):
In Reply to: 656 tappet cover posted by Vapet on March 28, 2011 at 11:38:39:
Since it is a cork style gasket I just use a little grease on both sides. You will most likely have to straighten your cover, especially around the screw holes. A damaged cover will not provide enen pressure on the gasket to get good sealing. Grease helps keep the cork soft enough that it does of better job of sealing the oil. Using grease does mean that there will always be enough residue to collect dust so it is not too popular with people wanting to keep their tractor pristine. Do not over tighten the cover or it will damage the gasket and will split your new gasket. The seals on the screws also get hard and will allow leakage around the screw holes.
You can use RTV sealant either on the gasket or instead of a gasket but if you do the surfaces must be absolutely free of oil or you will have oil leaks. Use just enough RTV to get a good seal. If you have beads squeezing out you have used too much.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
