If you have a distributor you need to check for battery voltage to your coil. With your ignition switch in the on position and the points open you should have voltage on both small terminals on your coil. If there's no voltage you need to back at the ignition switch using a volt meter or test lite. Hal PS: If there's no voltage at the switch you need to check the wire that's feeding battery voltage to your switch. It could be a bad connection or broken wire. You can run a separate wire from your battery to your coil just to see if the engine will start. This will bypass your ignition switch.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
