Re: Touch Control Overloading
Posted by Medfarm on July 23, 2000 at 12:05:09 from (209.162.29.163):
In Reply to: Touch Control Overloading posted by MoosieDog on July 23, 2000 at 09:58:51:
The Touch-Control hydraulic system is an open center system. When the hydraulic valves are in the open or non-movement position, the oil is circulated by the pump thru the valves back to the tank. When you operate a valve, the oil is pumped to the cylinder. When the cylinder reaches the end of the stroke, the oil has to bypass thru a relief valve. When hydraulic oil is dumped or unloaded across a pressure orifice (relief valve) or a restricted port, heat is generated. Since you said the valves are open and the oil gets hot after 2 hours of operation, I believe that the system has a continous blockage which eventually stops the flow of oil after the control valves. Check the return lines to the tank and the hydraulic filter. Check the internal components of the valves as a slight movement of the spool will cause this condition. As the oil temperature increases, the hydraulic system will do strange things. Good luck. Ray
Home
| Forums
Today's Featured Article -
The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
