No problem to use high side only except for you shifting out of gear problem. What I would do is take a look at the TA drive clutch through that top little four bolt cover and see if it is all intact. If it is you could just put the short linkage between TA clutch and main clutch and adjust it so TA clutch releases when pushing in main clutch. If some internal parts have been removed or clutch or planeterys welded or bolted solid you won't be able to do anything except major repair. I should say, utility may present problems getting at that cover, row crops are easy, not sure.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
