Posted by Janicholson on March 30, 2011 at 15:02:11 from (67.72.98.45):
In Reply to: Clutch or TA slipping posted by The West-ridge farm on March 30, 2011 at 14:06:26:
The low pressure symptom in the steering is also a TA factor. The direct clutch in the TA id hydraulically applied. If it gets low presure, it will slip, and since the TA rear clutch (sprague) and rear locking clutch Hydraulic are needed to have the TA work, and it does not, The issue is what to fix. If it were mine, I would repair the TA and put a new Control pump in it. The MCV pressure needs to be checked first. The pressure control valve could be causing the slipping in direct. Best of luck. JIm
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
