Posted by BruceS. on April 01, 2011 at 09:05:40 from (76.15.41.252):
Finally got everything apart on the MD last night. And what do I find but a really chewed up bolt in the bottom of the case which took out the constant mesh gear. Bolt size matched with one of the bolts holding on belt pulley delete plate. When I got the tractor, it had a plate made of sheet metal which I replaced with a new steel one. (I swear I did not drop anything into the transmission.) My "theory" is that since I started the tractor on a cold day, the grease was thick enough that it carried the bolt up and lodged in the gears. Does this sound feasible? The good news is, nothing else was damaged; bearings and all other gears look great. The trans. lube had no metal in it. Just thought everyone would like to know. The failure was manmade, not mechanical.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
