When you say you can't find the source of the leak, do you mean there is a puddle under the tractor, but you don't see where it comes from? Or is the fluid disappearing and you don't know where it is going?
If there is no fluid on the ground, check the crankcase. The 404 uses a hydraulic pump to circulate the transmission fluid, and the pump seal can fail and let the fluid into the crankcase.
If there is a puddle, clean the bottom of the tractor really well, let it sit and run, and you should be able to see where it leaks from.
I believe the PTO is separate from the transmission, everything else works from a common reservoir.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
