Posted by Owen Aaland on April 02, 2011 at 21:58:25 from (216.47.32.52):
In Reply to: Spun Bearing? posted by pete_5959 on April 02, 2011 at 08:08:01:
Take a # 194 light bulb, straighten the contact leads, and solder a few feet of electrical wire to each one. Add an alligator clip to the other end of each wire. Attach the leads to a 12 volt battery. You will now have a light that will fit through the spark plug holes.
You should be able to see where the screw is imbedded in the piston. You should be able to pop it loose with a long screw driver and pull it out with a small magnet. If the screw is brass, put a dab of grease on the end of the screw driver and use that to get the screw out.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
