To look at this logically, the main thing that would cause this problem is a lack of spark. This could be traced to bad plugs, wires, distributor cap, etc. I also suppose there could be some internal problem causing this failure. The thing to do would be to pull your plugs, make sure they are not cracked or are discolored bad. Then make sure your plug wires are good. If all of this checks out, get into the distributor and make sure everything is functioning correctly (for example, rotor button, points, etc.). If the tractor is in good condition otherwise, you will most likely find a problem with one of these components. Good luck, SF
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
