Farmall Tractors Discussion Board
Re: Farmall H engine problem
Posted by mjdelaney on January 04, 1999 at 09:52:50:
In Reply to: Farmall H engine problem posted by WayneR on January 03, 1999 at 13:41:40:
I had similar problems. I assume the engine is tuned up and valves/compression are okay. Ended up replacing Intake/exhaust manifold, gasket, and studs. Do you have the combination Gasoline/ Kerosene manifold set up? In my case I converted to straight gas.
I had trouble with Champion plugs too. I wondered if they changed the heat range but not the number. Shifted to AC a hotter plug and that solved my problems.
This is an aggrevating problem, but you will be well rewarded for your efforts.
Post a Followup
: Re: Re: Farmall H engine problem
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
