Re: Need help with 1206 Fuel problem??
Posted by SouthernFarmall on April 10, 2011 at 12:07:08 from (76.4.24.140):
In Reply to: Need help with 1206 Fuel problem?? posted by Ken Sweet on April 10, 2011 at 11:37:42:
I had a similar problem with my IH 464 diesel recently. I replaced both fuel filters, but it didn't help. I had to take them off again and check the gaskets. Turns out, the gaskets were put in wrong and sealed off the fuel flow. If your tractor is diesel (and for now I'll assume it is, since you mention an injection pump, when a gasser would have had a carburetor), you should be sure to bleed your lines when you replace the filters, otherwise it can cause a problem like yours.
It is hard to be sure what your problem is, but it DEFINITELY sounds like a fuel problem. Here is what is happening: You crank the tractor, run it out of fuel, it cuts off, fuel flows back to where it is supposed to be, and then it can crank back up.
Good luck, and keep us posted about what the problem was, SF
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
