Posted by Haas on April 11, 2011 at 06:53:15 from (75.200.34.125):
In Reply to: M 5th gear posted by DanR on April 11, 2011 at 05:37:14:
No need to split the tractor. You may be able to get at the problem by just removing the belly pump, clutch shaft and belt pulley gear assembly. You should be able to see what is wrong by just removing the belt pulley gear box, as that will expose the 5th gear set. Most likely, the internal teeth on the 4/5th sliding gear are worn to the point that there is not enough gear surface for it to stay in 5th. 5th gear drives straight through the top shaft to the differential. It will be an easier job to replace that gear if you also take the top cover off the transmission. It is very heavy and you will need a lifting device to get it off.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
