Posted by janicholson on April 14, 2011 at 11:29:11 from (199.17.6.77):
In Reply to: 140 6 to 12 volt posted by Wayne A Johnson on April 14, 2011 at 10:31:08:
If you have a generator, the voltage regulator may now have its cutout relay contacts welded closed. If was 12volt to begin with it was probably positive ground (even if it was 6 volt, it was positive ground) the VR closes instantly and is a short to ground when hooked up backwards. The VR and any melted wires are likely the only casualty. If it has an alternator, it likely has a bad diode in the rectifier bridge. Alternators are mostly negative ground (the way you hooked it up) so that was correct. Tell us more about what you have for a charging and ignition system. Jim
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
