blunted, either the engine is stuck, or if the tractor has been left out side in the weather some rain may have filled one cylinder and the engine has locked down for the engine can't compress H20. Fix,, remove plugs and attempt to pull it, if it frees up the pull farther to thoroughly clean and dry out the cylinders, clean and replace plugs and away you go. If the engine is stuck, Do Not Pull any more in gear you can damage the engine, Bend and break engine components Figure out what you are going to do, and go down that path as freeing up the engine shoot ATF into the cylinders and start by jacking up one rear wheel and rock it back and forth it will break free in a while,if you have to tear down that is another matter. If you would like hollar there is another way it is easier to tell on the phone than type it out call if you like My # IS 512-577-3837. or search other old post about stuck engines where I have posted I spoke of burning out the cylinder that is stuck to free up and engine. Hope this helps. Later, John A.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
