Posted by JWCarp on April 21, 2011 at 19:30:18 from (67.142.163.26):
I am trying out a 1256. The only thing I can find wrong is a couple of fuel leaks on the injection pump. One is on the injector line for #6 cylinder. I took it loose from the pump and put in new gaskets, and it still leaked. It appears that connections is worn on one side, which could be causing the leak. The other leak is in the bottom middle of the pump wher there is a plug on the engine block side and a cap on the side facing out. Does this sound like something expensive to fix or fairly simple for me or a pump shop to fix. I assume that I will need to get a new line for #6 cylinder to fix that leak. Any help will be appreciated.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
