Oil leak 806 Diesel....
Posted by funtwohunt on April 25, 2011 at 06:58:15 from (63.172.252.159):
Don"t know the correct name for the 1 1/8" or so tube that connects at the back of the engine oil pump then up turns with a 90 then ties into the casting on the back side of the oil cooler. Anyway, the I have a leak from the tube on the back side of the joint that ties to the casting with 2 bolts. It will leak a 1/2 cup or so before the motor gets warm enough and some times it stops after the motor is at operating temp. I have replaced the orings three times in the lst year or so. When I had the tube off I assembled it and made sure there wasn"t any thing bent out of place. When I bolted it together there wasn"t any binding at all. Where the o ring sets it looks fine, no groove at all. Still leaks in the same place. The last two times I replaced the O rings I took rtv silicone and run a good bead around the outside of the tube into the groove where the tube sets. Let it dry several days before I started the tractor and within 5 minutes it was leaking again from the same spot on the back. Is there a lot pressure and oil flow in this tube? Do I need to just get a new tube and end piece and start over? Can I put a small bead of rtv on the O ring itself before I put it together? The bottom o ring at the oil pump holds fine. Thanks for any and all help!! funtwohunt
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
