Re: M Farmall Lift Capacity
Posted by Wardner on April 27, 2011 at 13:26:36 from (209.86.226.34):
In Reply to: M Farmall Lift Capacity posted by sbainter on April 27, 2011 at 10:26:56:
Rob Maloney said: (quoted from post at 01:40:16 04/28/11) Thanks for your reply. Seems like I read in a manual that the Lift-All pump only had a capacity of 850 psi. The cylinders are small (probably 2"). Would larger cylinders command more lift, even if the pump is maxed at 850 psi? Thanks.
Lifting force increases by the square.
2x2=4
3x3=9
consequently, 9 divided by 4 equals 2.25 as much lifting power.
You could also use only one 4" x 8" cylinder and get 2 times the lifting capacity out of the hitch which I presume is a Worksaver brand. 2 ea 3" cylinders or one 4" should lift the bale but it depends where the adjustable lift links are attached to lift arms. I believe there are three holes/positions.
This post was edited by Wardner at 05:33:44 04/28/11.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
